Ford Charge Station Pro Data Extraction and Smart App Integration
Have you ever wondered how to extract data from the Ford Charge Station Pro (FCSP)? I stumbled upon this device made by Siemens and noticed it renders information via a webpage in the FordPass app. While exploring further, I found out that the site might be accessible through prod.ocpp.ford.com, but there’s no straightforward way to authenticate via a web browser. This led me to consider alternative methods, such as using clamps in my panel to track consumption within Home Assistant. If anyone has any ideas or suggestions, please let me know!
On another note, I’ve been experimenting with setting up a SmartApp using AWS Lambda with the Node.js SDK. I followed a basic sample application, but I’m encountering an issue where the SmartApp doesn’t install properly on my iOS device. The error message I receive is Something went wrong. Please try to install the SmartApp again. I’ve tried increasing the timeout and memory of the Lambda function, but it didn’t resolve the issue. I also checked the CloudWatch logs, and it seems the Lambda is responding correctly. However, the SmartApp installation still fails. If anyone has faced a similar issue or has any insights, I’d greatly appreciate your help!
Lastly, I came across a fascinating project where someone is using a Wemos Mini v3 with ESPHome to create a sensor. They were having trouble connecting to the device via HTTP after installing the firmware. From the logs, it appears the device is successfully connecting to the WiFi network but isn’t responding to HTTP requests. I wonder if there’s a specific configuration or troubleshooting step they might have missed. If anyone has experience with similar setups, sharing your knowledge would be incredibly helpful!
Let me know your thoughts or if you’ve encountered similar challenges. Happy tinkering!
