Foscam FI9816P Wireless Camera Buffering Issue Solved!
Hey everyone,
I wanted to share my experience with the Foscam FI9816P wireless camera, specifically regarding the endless buffering issue that plagued me for weeks. I hope this post can help others who might be struggling with the same problem.
First, let me set the scene. I purchased this camera as part of a security upgrade for my home. It was supposed to be my go-to solution for monitoring the backyard, but almost immediately after setup, I noticed a persistent buffering issue. No matter how stable my Wi-Fi connection was, the camera would constantly buffer, making it nearly impossible to use for real-time monitoring.
I did some research and found that this issue isn’t uncommon for this model. Many forums and support pages mentioned similar problems, but the solutions weren’t always clear. I decided to take matters into my own hands and experiment with different settings to see if I could find a fix.
After hours of trial and error, I discovered a few key settings adjustments that made all the difference:
  1. Adjusting the bitrate: Lowering the bitrate significantly reduced buffering, although it did affect video quality. I found a sweet spot where the video was still clear enough for my needs without constant buffering.
  2. Disabling motion detection: This was a tough one because motion detection is a core feature for security cameras. However, I noticed that motion detection was contributing to the buffering issue. By disabling it, the camera performed much more smoothly.
  3. Updating firmware: I also made sure to update the camera’s firmware to the latest version. While this didn’t completely solve the issue on its own, it did seem to improve overall performance.
  4. Optimizing Wi-Fi settings: I moved the camera to a different part of the house to ensure it had a stronger, more direct connection to my router. This helped stabilize the video feed.
After implementing these changes, the buffering issue was drastically reduced. The camera now runs smoothly, and I’m able to use it effectively for monitoring my backyard. While it wasn’t a perfect solution, it’s a huge improvement over the endless buffering I was experiencing before.
I hope this post helps anyone else who might be struggling with similar issues. If you have any additional tips or solutions, I’d love to hear them!
Best regards,
