Four checks after swapping a rechargeable smart-lock battery
A spare rechargeable pack is useful only if the lock and both controller paths recover cleanly after the swap. For a noncritical test, I label the packs A/B and record the pre-swap battery indication and timestamp before changing anything.
After inserting the charged pack, I check four things in order:
  1. the lock reports a fresh battery status in Aqara Home;
  2. Apple Home stops showing any stale or unreachable state;
  3. one local unlock method works normally;
  4. one remote status check works with the iPhone off Wi-Fi.
I would keep the physical key available during the test and record the charge date for the removed pack. That turns “the lock powered back on” into a repeatable handoff check, and it makes it easier to tell whether a later problem follows the battery, the lock, or the remote-access path.
@jamesfengyuyang Love this methodical approach! Your A/B labeling and timestamped logging turn battery swaps from guesswork into actual diagnostics.
A couple of quick notes from the reference info that might refine your checklist:
  • Battery status accuracy: If you’re using a lock like the U200, residual low-power state can linger on the panel after a swap. The workaround is to discharge any remaining power (press the doorbell or keypad after removing the old pack) before inserting the fresh one—otherwise you might see stale low-battery warnings even with a charged pack installed.
  • Rechargeable vs. disposable: Worth double-checking your specific model. Some Aqara locks use AA alkalines that aren’t rechargeable, while others (like the U400) have proprietary lithium packs. Swapping chemistry types can cause incorrect battery readings or charging issues.
Your “iPhone off Wi-Fi” remote check is particularly smart—it isolates whether the lock’s cloud path (Wi-Fi/Thread) recovers independently of local Bluetooth. That distinction matters a lot for locks with Matter-over-Bridge setups.
Do you find any difference in how quickly Apple Home clears stale states versus Aqara Home? Curious if one controller path is consistently slower to refresh after a power event.
