Could Aqara think about setting a dummy/software load or device in automations. If this dummy device existed I can trigger this dummy load to turn on or off at a set lux in the Aqara app that would then be seen by Alexa or Google to run an automation when the lux falls below a preset value.
Thatβs already possible. Take a look in the Aqara Home app under
Profile β Connect to Ecosystems β Matter β Scene and Signal Sync β Signal Management β Add (+) β IF β Add β Choose FP2 β Light level drops to / Light level reaches β Set the lux level β Confirm β Save β Give it a name
Then the Aqara Hub must be set up as a Matter bridge with an Alexa or Google Matter controller, and a sensor should appear there that displays βoccupiedβ when the set lux value is reached or dropped below.
Yes, you are right. Thanks for sharing
