Has anyone else experienced the FP200 picking up people through a wall?
Hello and welcome to the forum.you are referring to FP300 right?because there is no FP200 presence sensor.my be FP2
If you mean the FP2, then my FP2 is able to pick up presence behind a wall as long as there is a hole (for example a doorway) that allows the mmWave sensor to emit radio waves through said hole. The waves will bounce off the walls and it is able to sense people but with a but lower accuracy.
Sorry, FP2.
Nope, mine was going through a Sheetrock wall.
Then check the distance range as you have 3 options on the settings detection and chose there base on your zone
Yes, this is possible. mmWave can detect through walls relatively easily. You may have to keep this in mind with the device’s detection range.
