FP300 and Home Assistant
Love the Aqara products and starting my journey in expanding my home automation.
How do you din they work with Home Assistant, especially the FP300’s?
I have bought 2 and added them, my question is do people still use the Aqara Hub to connect their products or do they just connect them direct to Home assistant?
Cheers
Paul
Ive conneted my 3 directly to HA through z2m, quite easy, but the PIR/mmwave-sensors are quite confusing from time to time, ive defaulted to make a group of them and use that as a “motion” sensor
Thats how I connected mine, but as you say there are so many options for them . how do you group your sensors instead of running them seperate ?
Also, I have tried the disctance settings and Ai learning, but it still switches the lights on at night when the TV is on as I thought one of the features it will detect and recognise a monitor/TV and ignore it…
I have put a suggestion in on the aqara forum for them to create a Home Assistant Category as there must be 1000’s of home assistant users that use Aqara products as well … not just Crapple :rofl:
I run mine on an M3 and bridge them into HA over Matter. The tradeoff is that HA only gets occupancy, hold time, temperature, humidity, lux and battery, with no separate PIR or radar entities like Z2M gives you. The upside is I keep detection range and AI learning in the Aqara app. On the TV: the manual says AI learning filters glass, metal and mirrors. It doesn’t claim to ignore a TV. Aqara’s fix for false presence is narrowing the detection range to cut that area out, or lowering sensitivity, so see if Z2M exposes those settings.
I am running 8 Fp300s in that current setup and have HA controlling all my presence based automations, no automations in the Aqara app.
