FP300 presence detection reliability — PIR/mmWave fusion mismatch (data from 8 units, 7-day analysis)
Hi everyone,
I'd like to share some data from my own installation, hoping it's useful both to the Aqara team and to other users experiencing similar issues.
My setup: my home runs on Home Assistant with a full Aqara presence sensor deployment — 8x FP2 (installed everywhere I could run mains power) and 8x FP300 (installed everywhere only battery power was an option).
Installation / implementation details
- Platform: Home Assistant OS, self-hosted, core version 2026.8.3.
- FP2 integration: native Aqara Home / HomeKit integration over Wi-Fi (mains-powered units).
- FP300 integration: Zigbee2MQTT (MQTT discovery), not ZHA. Each FP300 is fully recognized as "Aqara Presence sensor FP300" with the complete entity set (presence/occupancy,
pir_detection,motion_sensitivity,absence_delay_timer,detection_range,target_distance,spatial_learning, etc.). - Zigbee2MQTT add-on version: 2.14.1-1 (bridge/app version 2.14.1), running as a Home Assistant OS add-on.
- MQTT broker: Mosquitto add-on 7.1.1.
- Zigbee coordinator: Sonoff ZBDongle-E Plus V2, coordinator firmware EmberZNet 8.0.2 [GA] (adapter
ember, not the olderezspmode), on its own dedicated Zigbee channel. - Mesh: a mix of mains-powered Zigbee routers/repeaters spread across two floors to give each FP300 a reasonably short hop to a router, not just to the coordinator.
- Sensor firmware: all 8 FP300 units report the exact same Aqara firmware version,
0.0.0_6542(verified individually per device via the Zigbee2MQTT/HA device registry), with no further update currently offered by Aqara for this model. - Sensor-fusion settings during this test:
presence_detection_options = both(PIR + mmWave combined) on all units,motion_sensitivity = high, all detection zones enabled (no zone masking). - I mention all this specifically to rule out "wrong integration path," "outdated app/firmware," or "one-off environment quirk" as explanations — the mismatches below are observed through the sensor's own published Zigbee attributes (Zigbee2MQTT just relays what the device itself reports), and every layer of the stack (HA core, Zigbee2MQTT, MQTT broker, coordinator firmware, sensor firmware) is up to date and identical across all 8 units.
The FP2 units are excellent. After months of use, they work flawlessly — no false negatives, no dropped detections, no oddities. Rock-solid, and honestly one of the best pieces of smart-home hardware I own.
The FP300 units are a different story. All 8 of them show, to varying degrees, the same core defect: the sensor doesn't reliably do the one thing it's meant to do — detect a person, whether moving or sitting still. The clearest and most measurable symptom is a mismatch between the raw PIR signal and the combined "presence" (occupancy) output, even with presence_detection_options set to "both" (which should make presence follow if either PIR or mmWave detects something).
Methodology
To make sure this wasn't just anecdotal, I pulled the full, non-deduplicated state history (Home Assistant significant_changes_only=false, so every single reported state change is included, not just the ones HA considers "significant") for both binary_sensor.*_pir_detection and binary_sensor.*_presence on all 8 FP300 units, over a rolling 7-day window.
For each unit, I merged the two boolean event streams into a single chronological timeline and flagged every interval where PIR was on while presence stayed off. Two details worth calling out for anyone trying to reproduce this:
- Mismatches under 30 seconds were discarded, since the two attributes are published as separate MQTT messages and a sub-second-to-few-seconds gap between them is expected/harmless — only sustained mismatches (≥30s) are counted below.
- A mismatch still open at the end of the query window (i.e. presence hadn't yet recovered when the data was pulled) is reported as "still ongoing," not artificially closed at the query boundary — this matters because naively closing every interval at the query end would overstate resolved episodes as still-active ones and vice versa.
7-day results (all units on firmware 0.0.0_6542):
| Unit | Mismatch episodes ≥30s (7 days) | Total time in mismatch | Longest single episode |
| Master bathroom (worst case) | 195 | ~350 min (~5.8 h) | 49.7 min |
| Hallway (1st floor) | 19 | ~180 min (3 h) | 36.7 min |
| Dining room | 50 | ~55 min | ~2 min (many short ones) |
| Laundry room | 2 | ~66 min | 43.0 min |
| Home office / study | 5 | ~27 min | 16.8 min |
| Entrance | 4 | ~47 min | <1 min (frequent, brief) |
| Kids' bathroom | 7 | ~21 min | still ongoing at time of check |
| Ground-floor bathroom | 0 | ~3 min | none — essentially clean |
A few things stand out:
- All 8 units show the defect to some degree — this isn't a one-off unit problem.
- Severity varies enormously between physical units — from "basically clean" to almost 6 hours/week stuck with PIR active and presence reported as clear.
- Firmware is not the differentiator: the best-behaving unit (ground-floor bathroom), one of the worst (hallway), and the master-bathroom unit all run the exact same firmware version (
0.0.0_6542). This points to per-unit hardware/calibration variance rather than a single firmware bug affecting all units equally — consistent with reports from other users in this forum and on the Home Assistant community forum, some of whom noted a replacement unit "just worked" while the original didn't.
Ruling out other explanations
Before pointing at the device firmware, I checked the more common alternative explanations and don't think any of them fit:
- Not a Zigbee network/mesh problem: these are the same two attributes,
pir_detectionandpresence, published independently by the device itself over Zigbee; Zigbee2MQTT just relays whatever the device reports on each attribute, with no OR/AND logic of its own applied on top. A mesh/latency issue would show up as delayed or missing updates on both attributes together, not as one attribute correctly tracking real motion while the other one — computed on-device from the same underlying radar/PIR data — reports the opposite. - Not an integration/quirk mapping issue: both entities individually track the raw sensor behavior correctly in isolation (PIR reliably flips on real motion; presence reliably flips on/off during "clean" periods) — it's specifically the fusion between them, which happens entirely inside the device firmware, that breaks down intermittently.
- Not a misconfiguration: all units were tested with
presence_detection_options = both,motion_sensitivity = high, all detection zones enabled, and (where present)ai_sensitivity_adaptivedisabled — i.e. already at the settings most likely to favor correct fusion, not stock/default ones. - Not explained by AI adaptive sensitivity: on the unit where this was tested explicitly, the mismatch and the static-presence false-negative both still occurred with
ai_sensitivity_adaptiveturned off, so the adaptive-learning feature isn't the (sole) cause.
Summary
With presence_detection_options = both, I'd expect "presence" to reasonably track "PIR is active OR mmWave sees something." What I'm seeing instead is presence reporting off for extended periods while the PIR is clearly still on — on every single FP300 I own, just to very different degrees. Given how central reliable occupancy detection is to this product's whole purpose, and given how well the FP2 performs in comparison, I think this is worth a closer look from the Aqara engineering team, especially given other independent reports of the same symptom (including one from an Aqara staff member acknowledging the risk, with a promised firmware fix that some users report didn't fully resolve it as of a few months ago).
Happy to share raw logs/history exports or run further tests if that's useful for diagnosing this.
Thanks!
