FP300 thread / matter in Home Assistant?
Anyone gotten this combination to work?
I’m not able to add it. The device is found, but the addon wizard just spins for a while and then states that the device cannot be added.
Not much logs to go on either.
Thanks
Hi, I have a few of them connected in Home Assistant. What is your setup? I use Home Assistant as my main Thread border router so I start to pair them with Home Assistant and then after that I get a new pairing code that I pair with the Aqara M3 hub as well.
I guess the standard questions is if you have a stable thread network close to the sensor? A few powered devices close by really makes a difference.
On one of my FP300 I had to move it close to my border router when pairing and then move it to the bathroom where it was supposed to be. Might be worth a try.
Hope it helps!
Yes, I have quite a few plugged in, but they won’t work on ZHA. You have to use Zigbee2MQTT instead
