”error persists across Zigbee and Thread"
Hi everyone,
I’m experiencing a persistent issue with my Aqara FP400 and would like to know if anyone has encountered the same problem.
The FP400 is physically installed in the same position and has never been moved. It is mounted in the corner of a shelf, at approximately 1.5–1.8 meters height , with the Aqara logo facing downward.
However, Aqara Home keeps showing this warning:
“Abnormal Installation Mode
A change in the installation angle of the current device has been detected, which may cause the device to malfunction. It is recommended to follow the guide to adjust the installation position.”
The important points are:
- The FP400 has not been physically moved or reinstalled.
- The warning persists after performing a factory reset .
- I initially had the FP400 connected to an M3 via Zigbee, running firmware 0062.
- I then switched the FP400 from Zigbee to Thread by changing the firmware/protocol.
- The same installation-angle warning was still present on Thread.
- I then switched back from Thread to Zigbee.
- After switching back to Zigbee, the FP400 is now showing firmware 0051 whereas it previously had 0062.
- The installation itself has remained exactly the same throughout this entire process.
My questions are:
- Why did the FP400 go from Zigbee firmware 0062 back to 0051 when switching from Thread back to Zigbee?
- Is this expected behavior, or is 0051 an older firmware branch that should be updated to 0062?
- Could the persistent “Abnormal Installation Mode” warning be related to the firmware/protocol transition?
- Is there a way to recalibrate the installation angle/IMU without performing another factory reset?
- Has anyone experienced this warning even though the FP400 was never physically moved?
At this point, I have reproduced the issue on both Thread and Zigbee, so I’m wondering whether this could be a firmware/calibration issue rather than an actual installation problem.
Any advice from Aqara staff @AqaraOfficial @expert @Caroline_Zzz @coccolino_26 or other FP400 users would be greatly appreciated.
Thanks!
