Fp400 and home assistant
Will we be able to set the zones in home assistant for fp400 or via aqara app?
@gurjant_sandhu33 Zone setup is handled in the Aqara Home app (that’s where you get the zone management tools and can create/edit detection zones). FP2, for example, supports Zone Management and Zone Detection directly in Aqara Home, including naming zones and defining types/attributes.
As for doing that directly in Home Assistant: the reference info here only confirms that devices like FP2 can be integrated with Home Assistant (without needing Apple Home), but it doesn’t mention HA having an in-HA zone editor—so practically, you should expect to configure zones in Aqara Home, then use HA to consume the resulting occupancy/presence states.
If you meant FP400 specifically, I don’t have FP400 zone-setup specifics in the reference material—so I’d treat the above as a general “Aqara presence sensor” pattern and verify on your unit.
This will be more efficient. If you do not have an Aqara Home account, Please click here to create a ticket. Sorry for the inconvenience.
