FP400/Matter: Trying to make sense of fallState and postureState values in aqaraOccupantLocationCluster.locationInfo
I just digged deeper into the debug logs of my local Matter Server and in particular the aqaraOccupantLocationCluster.locationInfo events of my FP400 unit.
Samples
2026-11-03 19:50:25.788 DEBUG  ClientEventEmitter   Received event aqaraOccupantLocationCluster.locationInfo on server-2-fff1.@1:12.ep1 targets: { targetId: 0, x: -152, y: 139, cell: 0, activityState: 1, fallState: 4010, postureState: 0, zoneId: 254, inZoneId: 0 } { targetId: 1, x: 133, y: 347, cell: 40, activityState: 64, fallState: 1010, postureState: 0, zoneId: 254, inZoneId: 0 }
2026-11-03 20:28:41.724 DEBUG  ClientEventEmitter   Received event aqaraOccupantLocationCluster.locationInfo on server-2-fff1.@1:12.ep1 targets: { targetId: 1, x: -83, y: 402, cell: 0, activityState: 11, fallState: 1010, postureState: 0, zoneId: 254, inZoneId: 1 } { targetId: 0, x: -80, y: 267, cell: 0, activityState: 72, fallState: 1010, postureState: 3, zoneId: 254, inZoneId: 0 } { targetId: 2, x: 142, y: 344, cell: 33, activityState: 7, fallState: 1010, postureState: 0, zoneId: 254, inZoneId: 0 }
While the event data mostly contains known and expected data such as x/y values, activityState and zoneID, i was suprised about reported values for postureState and fallState.
So now i’m wondering about the actual meaning and possible enumerations.
What I observed so far: unless AI Enhanced Person Detection is enabled, postureState is always reported with value 0 but may contain non-zero values otherwise. So it seems that postureState is actually bound to this feature.
@micharambou That’s some really solid reverse-engineering work on the FP400! I love seeing folks dive deep into the Matter cluster logs like this.
From what we know about the FP2/FP400’s capabilities, the sensor does support fall detection and posture recognition as part of its mmWave radar feature set. The FP2 can detect states including falls, and in its sleep/fall mounting mode, it tracks things like “someone is asleep” and “wake up” as automation conditions. The fallState values you’re seeing (like 4010 vs 1010) likely encode both the fall status and potentially confidence/severity levels, though the exact bitfield structure isn’t publicly documented.
Your observation about postureState being tied to AI Enhanced Person Detection makes total sense. The FP2’s posture detection generally distinguishes horizontal, vertical, and tilted postures, so those non-zero values (like 3) probably map to specific posture classifications when the AI feature is active. Without AI enabled, the radar likely skips posture inference entirely and just reports 0.
That said, the precise enumerations for fallState and postureState in the Matter cluster implementation aren’t something we have documented at the cluster attribute level. The values you’re extracting are lower-level than what’s exposed through the Aqara Home App automations.
You seem to be experiencing an issue with decoding FP400 Matter cluster locationInfo attribute values for fallState and postureState. You can contact customer support for assistance.
This is a custom cluster that is being exposed. Posture detection unfortunately hasn’t been launched for the FP400 yet so it’s hard to tell as there’s no documentation about it. You’ll to reverse engineer it
Here is the reponse from Aqara Technical support:
You used the HA plugin to reverse-engineer the various parameters in our FP400 sensor. However, we need to clarify that such third-party plugins only guess the names of the parameters inside the FP400 based on patterns. In fact, the items you mentioned, such as fall and posture state, do not exist.
Fallstate actually refers to the signal-to-noise ratio, and the target type was also incorrectly inferred as posture state.
In summary, the fall and posture functions do not exist. The meanings represented by different characters for target types are as follows: 0 person, 1 not person, 2 fan, 3 pet. The toggle for AI Enhanced Person Detection is used to verify whether the above target type detection functions are enabled.
