FP400 presence sensor bedroom or bathroom?
Hi guys, what ideas do you guys have in mind to use the FP400 in a bedroom or bathroom?
Thank you,
Already have mine up and running Matter over Thread in the master bedroom. I have “Bed”, “Non-bed”, and exits set as zones.
It took a few attempts to get the logic just right. At one point, my setup made it so that if I was standing at the side of the bed folding clothes, the light would come on and go off since I was in the transition area. But then I realized that during the day (i.e., Home mode) I didn’t need to differentiate between bed/non-bed. So I changed the logic so that the bed/non-bed transition was only a factor when in “Night” mode. So during the day, the bright overhead light comes on until the entire area is vacated. At night, dim red lamps on our nightstands turn on when we get out of bed. It’s surprisingly convenient.
Wow, that is great, I am so excited to get my hub to start playing with all of this, lol
I have been successfully using the FP2 (HomeKIt Only version of FP400) in our Master Bedroom and another in the Family Bathroom for a couple of years now.
Here you can see the template for my Master Bedroom, and the zones I’ve created. I have different automations for different zones, such as the bedside light on my side only comes on when in my zone.
For the bathroom, I’v personally not needed the FP2 and could have been happy with the FP300 as I’ve not needed the multi-zone. Although I have noted that others have found that useful.
I was thinking of the FP300 for the bathroom, but is there an issue with high humidity for the coin batteries? Like getting rust and damaging the device
That I can’t answer for you. See if the Fp300 has an IP rating.
@siobhanellis, thank you for your reply…
Do you have an good fan for extracting the humidity?as then it should be any issue regarding rusting more the FP300 have from what I know an temperature and humidity sensor too so you could control all that using automations
The specs say it’s fine with relative humidity 0% - 95%.
I’ll add here that you should probably go with the PS-S04E model and not the PS-S04D model which includes a metal mounting plate.
The humidity range in Aqara’s FP300 specifications includes an important qualifier: 0 to 95% RH, with no condensation. The last part matters more here than the 95% figure. It describes humid air, not a guarantee that water droplets on the enclosure or battery contacts are safe. Having a humidity sensor is not itself a waterproof rating.
I would choose a mounting spot away from direct shower spray and where condensation does not form on the device. Ventilation helps, but I would still check that spot during and after a shower. This is a specification-based caution, not a bathroom corrosion test. Aqara lists the same operating-humidity limit for PS-S04E and PS-S04D, so I would not choose between them on an assumed difference in moisture protection.
I’ve been using the FP300 (beta test unit) from the scratch! It’s running perfectly and had no issues. So I can recommend it
Here’s my review FP300 bathroom
for it :enqjol2bgmcitcrmcmgdyz_61:
@DEChrisE, nice review!
Well, the two models are identical units except for the mount. I would still not recommend the S04D model simply because the exposed metal mount will be more prone to rust than the plastic mount of the S04E.
I’m using one in our bedroom closet - so far so good!
Welcome to the forum, @lacroix !!!
I have one in the bedroom which switches the lights on if brightness is under a certain level during the day and some red low light during the night.
Another one is in the bathroom turning on the lights. I have a Nanoleaf Canvas mounted on the wall there which turn on simultaneously and plays random scenes.
Now I created a zone with the shower and once you enter it the Nanoleaf turns on a scene which changes slowly from blue to green, orange, red and purple in roughly 3 minutes. Purple then tells you you “wasted” enough water :wink:
As soon as you leave the shower that light resumes the random scene thing.
