FP400 update removes device from Apple Home
Just updated to 0062 firmware and the device is no longer exposed to Apple home at all.
Hub in Aqara shows 15 child devices, hub on Apple Home shows 14 devices.
Device is completely missing and has bricked all automations that were linked to it.
I’ve tried removing and resetting the device and it remains not exposed to Apple home.
This is unacceptable how do I roll back a firmware update?
If anyone else comes across this issue, it appears to be affecting zigbee connection only.
I’ve reset and changed the protocol to thread and that works.
But I would have preferred to have kept this in my wider zigbee network :frowning:
That is really odd thing.well thread for me is working perfectly.but you should also report it to Aqara support so they can investigate that issue
Same thing happened to me, I have two instances of my M200 hub in homekit, one connected via Matter and the other the traditional homekit method. The FP400 disappeared from the matter configured hub however the instance attached to the “homekit” hub was still there.
craigbarnes found that after firmware 0062 the FP400 vanished from Apple Home on Zigbee but worked again after switching it to Thread, while appletvinport saw it missing only on the Matter-paired M200 instance and not the HomeKit-paired one. That makes me wonder whether the device still shows up in the hub’s Matter bridge device list inside the Aqara app, and whether re-sharing the hub’s Matter pairing brings it back? It would also help to know which Zigbee-versus-Thread firmware combinations people are seeing this on.
Same in Home Assistant
And also one issue after updating the FP400 Zigbee version from firmware 0060 to 0062, with the device connected to an Aqara Hub M3, I started getting these errors in the device settings:
“Installation Issue Detected
May cause the device to not work properly.
The device installation angle has changed, which may cause the device to not work properly. It is recommended to follow the guide to adjust the installation position.
To recalibrate the installation method, go to the settings page and select ‘Switch the Installation Method’.”
However, nothing has been changed regarding the installation or position of the device.
Even after confirming that everything is fine, the warning appears again in the device settings.
Is anyone else experiencing the same issue?
I’ve not experienced any of those issues. The device has been flawless since switching it to thread (which is not my preferred connection choice).
Just currently enjoying a very reliable FP400 (which I don’t know if that is the update that improved its reliability - or the thread connection!)
My configuration was FP400 connected to the M100 via zigbee - connected to Apple home via matter.
My current stable configuration is FP400 connected to the M100 via thread - and then connected to Apple home individually via thread.
We do not have the same hub. That could be the problem.
Same thing happened again going from 0062 to 0063, the HomeKit instance stays but seems to fully reset in HomeKit (not the aqara app config) and needs to be setup again in HomeKit. The matter instance disappears, however it eventually reappears after power cycling the aqara hub.
