FP400 via G410 gets added multiple times to Home Assistant
I have two Aqara FP400 devices, one in my kitchen and one in my living room. I’m trying to understand why one of the devices behaves erratically in Home Assistant. The device has multiple times gone into “Unavailable” state in Home Assistant unlike my other FP400 which has worked smooth from the beginning. My automations through Home Assistant weren’t working so I started to debug the issue. This is the second or third time this particular device has acted this way. I have one device but I get multiple sensors in Home Assistant. This time I needed to once again add the device through Aqara App and reconfigure the zones and areas. The status in Home Assistant looks the following. There’s one device, but there are multiple entities. When this happens, I need to reconfigure my automations to use the new sensor entities. I am puzzled why this is happening on only one of my FP400’s and the other one works without any quirks. Both devices have the same latest firmware (60) and are connected through the same Aqara G410 Hub through Zigbee and exposed via Matter to Home Assistant. You can see the screenshot that there are multiple sensors which are in Unavailable state and the newly added sensors that state Clear or Detected. What’s causing this?
Same problem. Finally, I’m not alone with this problem.
I noticed something. I have two devices and only the Kitchen one is using the new 62 firmware. The other device reports 60 version and firmware up to date. The kitchen unit already previously did this kind of quirks so I don’t think this is a firmware version issue only.
