FP400 would be perfect if it had PoE
The FP400 looks awesome with the upgrades they put in. I’m on the fence about going with these vs Everything Presence Pro in a new build with ~30 in ceiling mounted sensors. I just really wish these had PoE built in so they could be networked by wire and I wouldn’t have to use a bunch of PoE to usb c adapters
Agree I’d buy it full price instantly if it has POE but I feel like it’s unlikely for these consumer devices to have POE :confused:
Also more likely that it will be much bigger if poe is added and also not appealing to usual consumers. :grinning:
Did I miss the full feature list somewhere?
Do you have enough PoE drops for this? I struggle thinking of using an ethernet drop or port for just a presence sensor.
Do you know if the FP300 battery powered or needs a power supply?
It is batteries powered
This type of sensors can’t be made as you want because adding such connection it could make the sensor bigger and not so very user friendly because to find the right place for it depends on each house or apartment and because they are not build the same , many will can’t even connect it.that is why this sensores that can be placed anywhere is better with power cord and not PoE.more convenient to place
If you take a look at devices like the Everything Presence Pro or the Apollo R-Pro-1 you’ll see they have a very similar form factor to the FP400 and include both USB C and PoE so it is possible. I actually designed a custom enclosure that gets mudded into the ceiling to house these sensors and all 3 of them fit into nearly the exact same footprint. I do understand that most “normal” users may not need PoE though
Yes, in this new build I had everything planned in for an Ethernet drop to each presence sensor location but I get where you’re coming from. It is definitely going to use up a lot of ports😅
I don’t want to do away with the USB C power, I’d just like to have the Ethernet port as another option. If you take a look at the Apollo R Pro 1 and Everything Presence Pro you can see that they both have USB C and PoE and are a very similar form factor to Aqara’s FP line
I do not know that sensor but what I do know is that many like me are just fine with the usb if works.it will be a good idea to have another option? sure why not but I think aqara is doing this sensors the way they think is better for the end user.but you never know my be they will release in the future with PoE.
One advantage of running such things off PoE is having everything on a UPS backup and being able to remotely power cycle devices like sensors and cameras that are in hard to reach places.
