I recently decided to install Home Assistant Core on my Libre Computer Tritium H3 running Armbian 22.08 Jammy. The journey was quite an adventure, but I wanted to share my experience and some tips for anyone else attempting this installation.
The Challenge
I started by following the official Home Assistant installation guide for Linux. Everything seemed to be going smoothly until I encountered an error: failing building wheel for cryptography. This issue had me puzzled for a few days. I tried various solutions I found online, including installing without virtualenv, but nothing worked. I even reached out to the community forums, where I found a similar problem from two years ago. Unfortunately, none of the suggested solutions applied to my case.
The Solution
After some research, I discovered that the issue might be related to the specific version of Python or the build dependencies on my system. I decided to update my system packages and install the necessary build tools. Here’s what I did:
bash
sudo apt update && sudo apt upgrade -y
sudo apt install -y python3-dev python3-setuptools libssl-dev libffi-dev
Once the dependencies were in place, I retried the installation. This time, it worked like a charm! The cryptography package built without any issues, and Home Assistant Core installed smoothly.
Tips for Others
- Check System Dependencies: Ensure your system has all the necessary build tools and libraries before attempting the installation.
- Update Your System: Sometimes, outdated packages can cause unexpected issues.
- Community Support: Don’t hesitate to reach out to the Home Assistant community forums. You might find someone who has faced a similar issue and found a solution.
Installing Home Assistant Core on ARMv7 was a bit of a hurdle, but it was definitely worth the effort. Now that it’s up and running, I’m excited to start integrating my smart devices and automating my home. If you’re considering this installation, don’t get discouraged by initial setbacks—keep troubleshooting, and you’ll get there!
Happy automating! ![]()
