I recently installed Frigate in Home Assistant, and it worked perfectly for a while. However, after adding a new camera, Frigate stopped functioning properly. Reinstalling it didn’t resolve the issue, and the logs aren’t updating as expected. Here’s what I’ve observed and tried so far:
Initial Installation Success: Frigate worked seamlessly with my existing cameras. I was able to monitor my property and receive notifications for any detected activity.
Adding a New Camera: I followed the standard procedure to add a new camera to Frigate. This involved updating the
frigate.ymlconfiguration file with the new camera’s details, including the RTSP stream URL, camera name, and other necessary parameters. -
Post-Installation Issues: After adding the new camera, Frigate stopped working entirely. The web interface became unresponsive, and I couldn’t access the live feeds or any recorded footage. The only indication of an issue was the lack of updates in the logs.
Reinstallation Attempts: I uninstalled and reinstalled Frigate multiple times, each time following the official documentation to ensure I wasn’t missing any steps. Despite these efforts, the problem persisted.
Log Analysis: I reviewed the logs provided by Frigate, but they didn’t offer much clarity. The logs showed that Frigate was attempting to start but failing to establish a connection with the new camera. There were also errors related to ffmpeg, which is used by Frigate for video processing.
Camera Configuration Check: I double-checked the configuration for the new camera to ensure all details were correct. The RTSP stream URL was verified, and I confirmed that the camera was accessible on the network. However, Frigate still couldn’t connect to it.
Seeking Assistance: I reached out to the Frigate community on forums and Discord, hoping someone else had encountered a similar issue. While there were a few suggestions, none of them resolved the problem.
Potential Solutions Tried:
- Adjusting ffmpeg Settings: I modified the ffmpeg settings in the
frigate.ymlfile, increasing theanalyzedurationandprobesizeas suggested in some forums. This didn’t help. - Resetting Frigate State: I tried resetting Frigate’s state by deleting the cache and configuration files. This also didn’t resolve the issue.
- Testing the Camera Independently: I tested the new camera independently using a different application to ensure it was working correctly. The camera functioned as expected, ruling out hardware issues.
Current Status: As of now, Frigate remains non-functional. I’m unable to monitor my property effectively, which is a significant concern. I’m hopeful that with the right troubleshooting steps or a fix from the Frigate team, I can get it working again.
Next Steps: I plan to continue troubleshooting by:
- Reviewing Network Configuration: Ensuring there are no network-related issues that might be preventing Frigate from communicating with the new camera.
- Updating Frigate and Dependencies: Checking for any updates to Frigate or its dependencies that might address the issue.
- Consulting the Community: Engaging more deeply with the Frigate community to see if others have found a solution.
I’m determined to resolve this issue and get Frigate back up and running. If anyone has encountered a similar problem or has suggestions, I’d greatly appreciate the help!
