Hello everyone, I’ve been working on setting up Frigate for motion detection in my home, and I wanted to share my experience and some tips that might help others facing similar challenges.
One of the key features I wanted to implement was sending a zoomed-in image of detected motion to both my phone and a digital picture frame in the living room. While the basic setup worked, I ran into an issue where the image being sent to the frame was the full camera snapshot, making it difficult to see clearly from across the room.
I tried using a shell command to copy the zoomed-in image to a specific location on my NAS, but I encountered an error: Error running command: cp /api/image_proxy/image.fd_cam_person /media/motion/Drive2.jpg, with a return code of 1. After some troubleshooting, I realized the issue was with the file paths. The shell command was looking for files in the wrong directory.
Here’s what I did to fix it:
- Adjusted the Shell Command: I modified the shell command to use the correct file path for the zoomed-in image.
- Checked File Permissions: Ensured that the NAS directory had the right permissions for the shell command to write to it.
- Reviewed the Automation Workflow: Double-checked the automation steps to make sure the image was being generated and copied correctly.
After these adjustments, the system worked perfectly! The zoomed-in image now displays clearly on both my phone and the picture frame.
For anyone else working with Frigate or similar systems, here are a few tips:
- Test Each Step Individually: Before setting up the entire automation, test each component (like the shell command) to ensure it works as expected.
- Check Logs Regularly: The error logs in Home Assistant are invaluable for troubleshooting.
- Document Your Setup: Keep notes on your configurations and any changes you make. This will save you time if issues arise in the future.
I hope this helps someone who’s facing similar challenges with their smart home setup. Happy automating! ![]()
