Hey everyone, I wanted to share my experience with setting up the Fronius Primo Energy Dashboard in Home Assistant. I had some initial issues, but I managed to get everything working smoothly. Here’s how I did it!
Initially, I installed the Fronius add-on through HACS and added the configuration to my config.yaml file. The sensors appeared in the developer tools, but I couldn’t see them in the energy dashboard. After some research and trial and error, I figured out the missing piece!
Here’s the step-by-step solution that worked for me:
Install the Fronius Add-on:
- Go to HACS and search for the Fronius add-on. Install it and restart Home Assistant.
Configure the Add-on:
- Navigate to the add-on configuration and enter your inverter’s IP address.
Set Up the Energy Dashboard:
- Go to the Energy section in the Configuration menu.
- Under the Energy Sources tab, add your solar production by selecting the Fronius sensors from the dropdown menu.
Check Your Configuration:
- Ensure that the sensors are correctly mapped in the dashboard settings. Sometimes, the sensor names can be a bit tricky to find!
Restart Home Assistant:
- After making these changes, restart Home Assistant to apply them.
Tips for Success:
- Double-Check Sensor Names: Make sure the sensor names in your configuration match exactly what’s shown in the developer tools.
- Use the Latest Add-on Version: Ensure you’re using the latest version of the Fronius add-on for optimal compatibility.
- Consult the Documentation: If you’re still having issues, refer to the official Fronius add-on documentation or the Home Assistant community forums.
Final Thoughts:
It’s incredibly satisfying to see all your solar data neatly displayed in the energy dashboard. Not only does it provide a clear overview of your energy production, but it also helps in optimizing your energy usage.
If anyone else is struggling with this setup, feel free to reach out, and I’d be happy to help! ![]()
Cheers,
