Hi everyone, I’m relatively new to OpenHAB and Linux, so I wanted to share my experience with installing and configuring the FS20 binding. After some trial and error, I managed to get it working smoothly, and I thought it might be helpful to others who are just starting out.
First, I installed the FS20 binding via Paper UI, which was straightforward. The interface made it easy to select and install the binding. However, I initially faced some confusion because, unlike the Homematic or Network bindings I had used before, the FS20 binding didn’t immediately show up in the Inbox. This led me to wonder if I had missed a crucial step in the configuration process.
After some research and reaching out to the community, I realized that the FS20 binding requires additional setup beyond just installation. I needed to configure the serial port settings to ensure proper communication with my FS20 devices. This involved editing the services/FS20.cfg file to specify the correct port and baud rate. Once I did that, the binding started working as expected, and my FS20 devices became visible in the Inbox.
I also discovered that using the log:DEBUG level for the FS20 binding was incredibly helpful for troubleshooting. It provided detailed logs that allowed me to identify and resolve connection issues quickly. I highly recommend enabling debug logging for anyone experiencing similar problems.
Overall, my experience with the FS20 binding has been positive. It’s a robust solution for integrating FS20 devices into an OpenHAB setup, and with the right configuration, it operates seamlessly. I hope this little insight helps someone else who might be struggling with the setup process. Happy automating! ![]()
