Hi everyone! I’m thrilled to share my recent success in integrating my Fujitsu Airstage air conditioner with Openhab. This journey was a mix of curiosity and determination, and I’m excited to walk you through it.
My Setup
I have the Fujitsu ASYG12KMCF model, which comes with built-in Wi-Fi, making it a perfect candidate for local network integration without the need for additional dongles. My goal was to control the AC directly through Openhab, bypassing the Fujitsu cloud.
The Process
Understanding the REST API:
The Fujitsu Airstage system provides a REST API that, unfortunately, isn’t well-documented. I relied heavily on GitHub - danielkaldheim/ha_airstage for guidance. -
Configuring Openhab:
- HTTP Binding: This was crucial for sending and receiving REST requests.
- JSONPATH Transformation: Used to parse the JSON responses from the AC.
- Java Script: Custom scripts were written to handle commands like turning the AC on/off, changing the temperature, and adjusting the mode.
Channels Setup:
- Power Control: On/Off functionality.
- Temperature Adjustment: Both retrieving and setting the target temperature.
- Mode Selection: AUTO, COOL, DRY, FAN, HEAT.
Custom Scripts:
I created several JavaScript files to handle different aspects of the AC’s functionality. For example,airstageSendTemp.jsconverts the desired temperature into the format required by the API.
Challenges and Solutions
- Parsing Responses: Initially, I struggled with correctly parsing the JSON responses. Using JSONPATH made this process much smoother.
- Temperature Conversion: The API requires temperatures to be sent as multiples of 10 (e.g., 190 for 19°C). A custom script handles this conversion seamlessly.
This integration has been a game-changer for my smart home setup. The ability to control my AC through Openhab has added a new level of convenience and automation. I’m now exploring how to integrate this with my existing routines, like automatically cooling the room when I arm my security system.
If you’re considering this integration, I highly recommend starting with the GitHub repository I mentioned. It’s a fantastic starting point, and with a bit of tweaking, you can tailor it to your specific needs.
Happy automating! ![]()
