Fun with power monitoring automations!
I was nervous buying a Meross MSS315 Matter over WiFi smart plug, as there isn’t a huge amount of anecdotal info on pairing and monitoring power usage with the Aqara M3 hub.
Meross made it awkward to setup and I needed to disable 5Ghz WiFi on my router before the Meross app on my Samsung phone would “talk” to the plug!
Once the plug was set up in the Meross app and firmware updated, I shared it’s Matter credentials to the Aqara app. At first, the plug only appeared as a simple plug with on/off - I needed to set up the power monitoring services in my Aqara app, which then created a second separate power monitoring device.
This is the fun part. Our laundry room is separate from the house and we constantly forget to collect our clean clothes. My partner asked for an “annoying” reminder, so we cannot ignore it!
I created a few automations based on the power usage of our (not-smart) washing machine.
1- when the power usage rises to 50W, this “run once” automation enables the next automation.
2- the next “run once” automation waits for the power usage to return to 2W and sends a custom notification to every phone with the Aqara app to say that the wash cycle is complete and enables the next automation.
3- This third automation sends a notification for every 15 minutes that the machine sits at 2W. It also plays a custom MP3 of a clown horn that I had uploaded to the audio library of the M3 hub. This automation runs until someone goes to the laundry room and presses an IKEA matter button which triggers a final automation which cancels this automation and enables the first automation which will then wait for the washing machine to be used next time.
My partner hates it, but it works perfectly! We collect the washing straight away!
HAHA it seems like a really annoying but effective automation. :rofl:
Any news for the automatisation base on the power consuption for the US outlet? The only trigger available are still turn on, turn off, is on or is off.
Seeing your “expert” status, I’m guessing this is a US specific problem and you will probably know, but putting this out there for those that get stuck with a simple on/off switch.
I was initially stuck with a simple switch and with some tinkering, I found that energy consumption services were not turned on in the Aqara app by default.
Tap Explore - choose Services at the top of the screen - Energy Consumption. Tap on the cog icon and one of the following options has some on/off toggles and I remember maybe having to select the plug, or maybe it just appeared. I forget.
After a period of time, the hub created what looked like a separate device for energy monitoring of the plug - but when tapping on the plug accessory, I can see all that I need and automate based on all the capabilities of the plug.
Haha, great one. Thanks for sharing
Yes. The us outlet dint have this feature yet.
