G100 both in Aqara app and HomeKit security video
I have 2 separate g100 cameras, one at my place and one at my sister’s place and they both records events randomly. And even weirder the events are different in the Aqara app and Apples HomeKit security video. For example, there was an event (person detected with the recording) at 12:07 pm in both Aqara’s app and in HomeKit but at 1:53 pm and 2:43 pm in HomeKit there are two events with recordings and at 6:38 pm there is an event and recording only in the Aqara app. I don’t understand why. My sister has noticed the same thing that that events that should record but that don’t. She does get events with recordings but not for all the events that she should get. She knows someone walked through the cameras field of view but no recording and there some events do get recorded for whatever reason. Is there something that can make it so that all events get recorded by one at least but hopefully both the Aqara app and HomeKit. Thank you.
Check a few settings since you didn’t mention if you did or not. Open/tap the camera feed in Apple Home at the top tap the cog wheel icon scroll down to Recording Options and make sure those are set the way you like.
Those need set for each camera on each device you use Apple Home with, those don’t sync across devices. Also make sure you have the Activity Zones set the way you want on each device. Those are also in the same section in the Home App.
Hope that helps?
