When I tell Siri to turn on the hallway lights the G100 spotlight turns on. I had the camera using Hallway location and thought I should change it to Entryway just in case this was the problem. It wasn’t.
I have another G100 in another room but this one doesn’t have the problem. I just bought these and both have updated to the latest firmware. Only one has the issue. Any thoughts about this?
Hi there! And a big warm welcome to the forum!
I’m familiar with this from the G5 Pro, which also has a built-in spotlight.
Take a look in the Apple Home app at the room where the camera is assigned. Press and hold the camera image until a menu appears, then select “Accessory Settings”.
Check to see if it says “Show as Single Title” or “Show as Separate Titles”. I prefer the setting that lets you control the light separately.
Then tap on “Accessory” (there should be a number next to it). On the G5 Pro, this includes the alarm system, the spotlight, and the motion sensor. Tap the spotlight and then tap the settings icon in the lower-right corner. Here, you can assign the light to a room (independently of the camera) or give it a more recognizable name. I just assigned the light in my hallway to that exact room in Apple Home and assigned the camera light to a different room, so Siri doesn’t make any connections.
So check again to see if you only changed the camera’s room assignment and whether the spotlight’s room assignment might have remained the same.
Under Group → “Group with Other Accessories…”, you can create groups for multiple lights. It’s best to double-check all rooms and all devices to make sure there isn’t a group that was created that includes the camera’s spotlight.
Make a scene which turns on the hallway lights, but don’t include the hallway light. After that, Siri will execute the scene when you tell it to turn on the hallway lights.
I have the same issue, I bought recently 5 cameras G100 although the spotlight is deactivated 3 of the cameras turns the lights on , and had to manually turn them of the Aqara app.
