I have g100 security camera. I find that randomly the light will be enabled. As far as I can tell this is not controllable through Apple Home, you, have to choose the Aqara app. So I am unsure how this is happening
@zoinks Hey there! That’s definitely a puzzling one — random light activations on the G100 when you’re not controlling it through HomeKit. Let me help you troubleshoot this.
A few things to check:
Night vision settings — The G100’s light behavior is closely tied to how night vision is configured. Head to Aqara Home app > Accessories > G100 Camera > Device Settings > Camera Settings > Video Settings > Night Vision Method. If it’s set to spotlight night vision, the light will turn on in dark conditions automatically. You can try switching to infrared night vision (“always on” or “automatic”) to see if the random activations stop.
Ambient light interference — If there’s any light source hitting the camera lens (even briefly), it can cause the spotlight to trigger or cycle. Try repositioning the camera angle to rule out reflections or passing headlights.
Firmware check — Make sure your G100 is on the latest firmware, as there have been improvements around camera behavior.
Automation audit — Double-check both Aqara Home and HomeKit for any hidden automations, including the “recommended” scenarios in Aqara Home that are easy to overlook. The smart log timestamps can help you correlate whether an automation triggered the light.
If none of these explain the pattern, it’d be worth capturing the exact times it happens along with your device ID for the support team to dig into logs.
Hope that narrows it down! Let us know what you find.
I’d take a look in Apple Home first. The G100 spotlight shows up there as a light, so “turn off all the lights” or a scene for that room can include it. Someone else here had Siri turning on the G100 spotlight a few days ago, and it was the same thing.
In the camera’s accessory settings you can see which room the light is in. Moving it to another room, or taking it out of your scenes, should fix it.
