Hi all,
I’m building a Matter controller (not SmartThings/Apple/Google — a custom controller) and streaming the G350 over Matter WebRTC. I’ve hit an intermittent video problem on firmware 4.5.80 and I’m hoping someone here has seen it or can route it to the right engineer.
Symptom: WebRTC negotiation succeeds every time — ProvideOffer is accepted, the camera’s answer arrives, ICE connects, DTLS completes, and audio flows. But on a subset of sessions, zero video ever arrives while audio keeps playing. Other sessions, with identical code, stream 1080p/720p video perfectly. It’s a per-session dice roll.
What I’ve confirmed (measured, not guessing):
- I ran
tcpdumpon the receiver’s NIC. On the failing sessions the camera sends only small, uniform audio-rate packets (~5 KB/s, largest ~700 B DTLS) and no video-sized packets at all — so this isn’t packet loss in transit or a decoder issue on my side. The camera simply never puts video on the wire. VideoStreamAllocatesucceeds and reports an allocated stream on the failing sessions too — so allocation is not the same as transport; a successful allocation doesn’t guarantee the camera actually sends video.- Retrying (EndSession + a fresh ProvideOffer, with backoff) eventually lands a good video session, but no controller-side retry reliably recovers a given stuck session.
Questions:
- Has anyone seen this narrow case — session connects and sends audio but no video — and does a power-cycle clear it? Or is there a controller-side trick (a specific re-offer, stream re-allocation, a particular
streamUsagevalue) that reliably gets video to start? - On 4.5.80, is anyone getting video from the G350 over Matter WebRTC every time, or does it also hit the occasional audio-only session? Trying to tell whether this is firmware-side or something in my negotiation.
Possibly related: SnapshotStreamAllocate returns CONSTRAINT_ERROR (0xCF) on 4.5.80 even with the camera’s own advertised params (640×480 and 1080p JPEG @30fps), so snapshot allocation also looks broken on the latest firmware.
Happy to share pcaps and logs if an Aqara engineer wants them. Thanks!
