G4 Doorbell - best batteries m
I run my G4 doorbell on batteries - I find different batteries last longer than others. Anybody found the best batteries to use?
Ultimately want to get it wired eventually, no current wiring there so would be some Electrican work
@dcunliffe98 Great question, and you’re absolutely right that battery choice makes a real difference with the G4!
For the Smart Video Doorbell G4, Aqara officially recommends LR6 alkaline AA batteries — these are your standard 1.5V alkaline cells. The doorbell supports either AA batteries or rechargeable lithium batteries with a 1.5V discharge voltage.
A few key tips from the specs:
  • Avoid NiMH rechargeables (1.2V output) — they’ll work but give you inaccurate battery level readings and noticeably shorter runtime
  • Don’t mix old and new batteries, or different types — this seriously cuts battery life and can affect safety. Always replace all 6 with fresh, identical cells at once
  • With typical use (~35 activations/day at 10 seconds each), you’re looking at roughly 4 months on quality alkalines
If you want to extend life before you get that wiring sorted, also check whether you’re in Normal Mode or Power Saving Mode — the latter disables PIR detection and only wakes on doorbell presses or app checks, which stretches things considerably.
Wiring’s definitely the endgame for convenience though — when externally powered, the G4 stays awake full-time with no sleep cycles.
What batteries have you been running so far? Curious how your real-world experience compares to the spec estimates.
