G400 home assitant integration
Hello, I am trying to integrate my G400 video doorbell into Home Assistant. Currently, everything works fine in the Aqara Homa app, but I am having trouble integrating it into Home Assistant. Can anyone help me? Perhaps a link to a good video tutorial?
Hi, @Expert.
Anyone with experience setting up G400 for Home Assistant, please help.
Hi. I don’t have a G400, but it should probably work exactly the same way as with a G3 via the HomeKit Device integration:
Home Assistant automatically detects the G400 in Devices and Services, but when I click Add, the next screen saying “please wait, the Control Panel is starting” seems to freeze. The circle keeps spinning, but nothing else happens.
SOLVED.
After the automatic detection of the G400 in Devices and Services, I completed the configuration in Home Assistant on the phone. What didn’t work on the computer did work on the phone.
That’s probably got something to do with the way things get set up. e.g. Matter devices need to be via phone.
It should work over the network (LAN/Wi-Fi) without a smartphone. Next time, try clearing your browser cache, or press Ctrl + F5 in Windows or Command + Shift + R on a Mac. However, if it worked on your smartphone, that’s fine too.
You can also as an alternative option install the G400 in Home Assistant using the Generic Camera and RTSP option.
In the Aqara app go to the G400 camera settings-more settings-RTSP Lan Preview-Enable (note all the settings).
Open Home Assistant go to settings-devices & services-add integration-generic camera and use all the information noted above.
The Home Assistant Generic Camera option works very well with Aqara cameras.
I use the Picture Glance card but you can use any camera card you like. The Picture Glance card allows you to add doors and lights or locks to the screen that might he handy to have access to from that view of camera.
as others have said, the RTSP option is the best, to intergrate with home assistant. Button can be done via matter, but if not really needed with doorbell chime in my opinion unless you want light blinking.
