G410 does`t work, when Internet connection is down
Hello,
my G410 does`t transmit the camera video to my mobile, when Internet connection is down. The doorbell is working. I explicitly talking about a connection in my local WLAN!
Why is it neccessary that I need a WAN connection for a local access? I dont want to store videos on the cloud or need any service from elsewhere.
I hope that you can give a sufficient advice, or I will definitly send it back to amazon! I need a system, which can work autonomously, when I want it.
Best,
Frank
@frenki_d Hi Frank, I totally get your frustration — wanting local-only access without WAN dependency is a completely valid setup, especially for privacy-focused users.
Looking at the G410’s specs, there are a few things worth checking. First, the doorbell does support end-to-end encrypted video streaming directly to the Aqara Home app and has RTSP for local streaming capabilities. However, the initial app connection and authentication typically still route through Aqara’s servers, which is likely why you’re hitting this wall when the internet drops.
A couple of questions to help narrow this down:
  • Are you trying to access via Aqara Home app, HomeKit, or RTSP/Home Assistant? The behavior differs by path. HomeKit Secure Video, for instance, requires an Apple Home Hub on the same LAN for remote/mobile access — but even then, some handshake traffic may still need WAN.
  • Is your phone on the same local Wi-Fi as the G410 when testing, or on mobile data? True local LAN access should behave differently than “remote” access.
For fully offline operation, RTSP streaming to something like Home Assistant is your most promising route — that bypasses Aqara’s cloud entirely once configured. The G410’s Matter bridging and local face recognition also work without cloud dependency, but the initial app pairing and video stream establishment is where things get sticky.
If you’ve confirmed RTSP isn’t working offline either, or if the app simply won’t authenticate without internet, that’s a legitimate limitation worth escalating. For a definitive answer on whether this is expected behavior or a configuration issue, I’d recommend reaching out directly:
Contact the Aqara Home App Customer Service Team (Profile > Help & Feedback > Customer Service) or scan the QR code:
This will be more efficient. If you do not have an Aqara Home account, please click here to create a ticket.
Would love to hear what you find out — this is exactly the kind of real-world edge case that helps the whole community understand where the “local-first” marketing meets the actual implementation.
I’m using the Aqara App and both mobile and G410 are on the same WiFi.
