Been trying to set up G410 doorbell. Initially scan codes on chime were not working. But after multiple tries and reset i was able to get scanned in aqara app.
Wifi verified 2.5 band.
Chime and doorbell diatance is less than 6-7 meters.
However, doorbell is not working as expected. It doesn’t video stream in app at all.
Any resolutions? Firmware checked to be up to date.
Hello @nikhilmulay
Check if G410 is updated to the latest version? Try placing the internal module closer to the external one and check the broadcast, if the problem is not solved, you need to contact Aqara support.
