G410 Firmware issues
My G410 attempts to update to 4.5.20_0052.0108, gets to 99% and will not complete the update. Any suggestions to get it updated? Also, I’m not getting any video feed from the camera. The hub is about 25 feet away from the doorbell.
I was able to get it to update by connecting it to a 2.4 network. Now, can’t get the camera to connect to the hub.
@reidronb Glad the firmware update worked out on 2.4 GHz! For the camera connection issue, a couple of things to check since your hub is about 25 feet away from the doorbell:
Distance & Signal
That 25-foot gap with walls in between can definitely be a weak point for the G410. The reference info suggests keeping the doorbell and repeater/chime within a tighter range to avoid streaming failures and connection drops. If possible, try moving your chime/repeater closer to the doorbell temporarily to see if it pairs.
Wi-Fi Interference
Since you had to force 2.4 GHz for the update, double-check that your main network isn’t broadcasting both bands on the same SSID, which can cause the camera to try hopping to 5 GHz and fail. Also worth changing your router’s Wi-Fi channel if you’ve got neighbors crowding the spectrum—this can cause the exact freezing and choppy behavior described in the video troubleshooting.
Quick Power Cycle
Unplug the G410 for about 10 seconds, then try the pairing process again fresh. Sometimes the partial update state can leave the camera in a weird handshake loop.
If the camera still won’t connect after tightening up the distance and checking for interference, this might need a deeper look at the hardware side. You can contact the Aqara Home App Customer Service Team (Profile > Help & Feedback > Customer Service) or scan the QR code:
This will be more efficient. If you do not have an Aqara Home account, please click here to create a ticket.
