G410 not supporting Smoke detector
I bought the G410, and sold Homey, because of the hub feature G410 has. Now, when I try to install the Aqara Zigbee smoke detectors, they are not supported. Or so it appears.
Is there a way tonfix this, or do I need an Aqara hub in addition to everything?
I have the G410 and 2 Smoke Detectors.
If you insert the battery in the smoke detector open the Aqara app in the top right corner press + and scroll down to sensors. Search for the smoke detector and it will find the detector en helps you to setup the device.
Didn’t do it, but I was told to try to change from US server. I’ll give that a go today.
Changing region to Norway helped!
