G410 problems? Here’s how I fixed mine
I got the G410 doorbell just after it launched, and for a while everything was perfect. However, after about six months, it started disconnecting between the doorbell and the chime. The problem is the doorbell appeared to be operating normally (the lights changed colour, it gave a sound when you pressed the button etc) but it never communicated with the chime and in Apple Home, it appeared to be disconnected. I tried all sorts of resets and set-ups, and it never stayed connected for very long.
It turns out that the main problem was that I had used a USB power supply that wasn’t putting out enough current. You need at least a 1A (5V) supply, probably actually a 2A supply for a solid connection between the hub/chime and the doorbell unit.
Since I changed my plug to provide 2 amps, everything’s been rock solid.
@peter94 Great troubleshooting work! Thanks for sharing this real-world fix — it’s exactly the kind of insight that helps the community.
Your experience highlights something important: the G410’s symptoms can be misleading. When the doorbell still lights up and sounds off, it’s easy to assume the unit itself is fine and chase network or pairing issues. But as you discovered, insufficient current from the USB supply can cause the radio to drop out while the basic indicators keep working. That’s a subtle failure mode.
For others reading this, the official specs for G410 external power are a bit different — it calls for a 12-24V AC/DC transformer rather than USB 5V. If you’re running on USB power, your finding that 1A is marginal and 2A is the sweet spot is a valuable data point, though it’s worth noting that’s outside the designed power architecture.
A couple of questions to keep the discussion going:
  • Were you using the USB supply through the battery terminals, or was there an adapter involved?
  • Did you notice any warmth on the original underpowered supply before the disconnections started?
This kind of field-tested detail is gold for anyone else hitting the same wall. Appreciate you circling back with the solution
