I would like to compare troubleshooting results with other G410 owners using RTSP in Home Assistant/go2rtc. These are results from my retest on 14 October 2026, not a claim about the current firmware or a confirmed root cause.
After replacing the power supply and cable, I tested again at the same location on 5 GHz Wi-Fi. No camera, Home Assistant or Matter restart and no firmware change was made during this test.
What I observed:
- A short network test received all 40 packets, with 0% loss and an average round-trip time of about 3.5 ms. This does not establish long-term Wi-Fi stability.
- The configured RTSP port 8554 was reachable.
- Home Assistant snapshots were intermittent: in one set of three requests, the results were HTTP 500, 200 and 200. A G5 control camera returned HTTP 200 on all three snapshot requests.
- Direct FFmpeg RTSP-over-TCP decoding timed out on all four attempts: one targeting 300 seconds and three reconnects targeting 30 seconds. The long attempt reported missing H.264 codec parameters/frame size; the saved progress output showed no decoded frames.
The existing HA/go2rtc camera consumers remained active, so concurrent RTSP access was not isolated. A stronger-Wi-Fi comparison was also still outstanding. Replacing the power supply and cable did not make RTSP reliable in this test, but these results do not establish whether the cause is firmware, Wi-Fi, hardware or concurrent clients.
Has anyone seen the same combination of a reachable RTSP port, intermittent snapshots and no decoded frames? In particular, does testing with only one RTSP consumer change the result for you? If you have a stable G410/HA setup, please share the firmware version and whether HA uses a single restream or multiple direct connections. I would appreciate suggestions for the next controlled test.
