I wanted to share my G410 troubleshooting experience in case someone sees an update repeatedly offered even after the app reports success.
Symptoms
- Live view was unreliable in both Aqara Home and Apple Home. When opening the stream, the indoor chime’s LED changed from steady blue to red, but the picture sometimes did not load. Closing the app returned it to blue.
- The doorbell button sometimes needed several presses or did not appear to react.
- Firmware showed 4.5.20_0052.0090, with 4.5.20_0052.0108 offered. The app repeatedly reported a successful update, but the displayed version stayed unchanged and the update was offered again.
What I had already tried
I restarted both units, performed factory resets and set them up again, and retried the update several times. I tested 2.4 GHz and 5 GHz Wi-Fi and checked the connection to my FRITZ!Box. The indoor unit had a 5 V / 2 A supply, the outdoor doorbell had external power, and I also tried a short distance between the two units. At that stage, the problem persisted, including on 2.4 GHz.
What Aqara support clarified
Support told me that the indoor chime had updated, while the outdoor doorbell was still on older firmware. They explained that the outdoor unit communicates through its dedicated chime and that interference on that link could prevent its update.
Their recommended next steps were to hold the reset button on the back of the outdoor doorbell for 15 seconds, power it with batteries, place it close to the chime, and retry the update. These are the support recommendations; I cannot attribute the recovery to one particular step.
Follow-up
During later troubleshooting, the yellow blinking stopped, the indicator changed to blue and then red, and live view became available again. This happened before my subsequently confirmed update, so I would not call the update a proven fix for the live-view issue.
After that update, my firmware screen showed:
- Current firmware: 4.5.80_0002.0108
- Doorbell firmware: 4.5.5
My practical takeaway is to check the displayed versions for both components after an update, rather than relying only on the success message. I do not yet have a confirmed root cause or enough follow-up to claim a permanent fix.
Has anyone else seen the chime update while the outdoor G410 remained on older firmware? Which step helped you complete the outdoor unit’s update?
