G5 Camera spotlight issues - POE version with HomeKit - Tip
I’ve had issues with the spotlight turning on. I had to keep going into the app to turn it off but couldn’t figure out why it kept coming on.
Well, it might be because I had the camera in a zone in my Apple HomeKit setup. When I asked for all the lights to turn on, it seems the light on the hub can be controlled via HomeKit. Fixed the issue, by creating a new zone - called outside and put the camera in that zone. Seems I’ve found my user error! :man_facepalming:
Good find!
Good find!
I’ve been having that same problem and thats definitely the reason! Thanks for figuring that out!
Thanks. Sometimes this issue popped up at my side. This solved it
Thank you for this tip. I have the same problem. However, I don’t see “zones” in my Apple HomeKit setup. Do you mean “rooms”?
