G5 Pro (PoE) Factory Reset Not Working
I have a G5 Pro (PoE) that will not reset to factory defaults. I was able to do the network reset, but not a full reset to fully wipe the device. Any advice?
Hi, and welcome.
Did you do it exactly as described in the instructions? You have to press the button very quickly, one after another. And I’m not sure right now if 10 times is really enough. Just press it a few more times than 10.
Source: https://cdn.shopify.com/s/files/1/0710/9220/7830/files/Camera_Hub_G5_Pro_POE_User_Manual-EN.pdf?v=1740034153
Have you tried holding the reset button for the full recommended time while the device is powered on? If the network reset works but the full factory reset doesn’t, it could also be related to the firmware. I’d check the reset procedure for the exact G5 Pro PoE model and try updating the firmware if possible
