Hi all. I have a wired (PoE) Aqara Camera Hub G5 Pro and I’m seeing the live RTSP stream fall further behind real time the longer it stays connected. Has anyone else noticed this, or found a fix?
What I’m seeing
- Viewing
ch4directly in VLC on the same network, with nothing else involved, the stream was about 5 seconds behind real time. 17 minutes later it was about 8 seconds behind. - That’s roughly 10 seconds an hour. Closing the stream and reconnecting brings it back to near live.
- It looks the same on a Home Assistant dashboard, which is how I first noticed it.
Stream details (VLC): H.264, 640x360, 20 fps, about 37 kb/s, AAC audio.
What I’ve ruled out
- Network: a 60-packet ping to the camera showed 0% loss and a 2 ms average. It’s on wired Ethernet with a PoE injector.
- Bandwidth: the stream is tiny.
- Home Assistant and my dashboard device: VLC connects straight to the camera and shows the same delay.
- Camera type: an Aqara G410 doorbell on the same network, viewed the same way, stays close to real time.
Questions
- Is this a known behaviour of the G5 Pro’s RTSP stream, and is there a firmware fix?
- Is there any setting for the keyframe interval or stream buffering?
- Has anyone found a workaround apart from reconnecting regularly? I’m currently reconnecting the stream every 30 minutes.
