G5 Pro Thread 1.3 has split my network for a month — is a Thread 1.4 update coming? Aqara, please answer publicly
I’m posting this publicly because I want an answer other owners can see too.
My setup: a large Apple Home / Home Assistant house with 18 Thread border routers and ~38 Thread devices. I am heavily bought into Aqara — four G5 Pros, a G350, an M3, U100/U300/U400 locks, FP300s, and more.
For at least a month, across four network scans (Oct 13 – Nov 3), my Thread network has been split into two partitions on the same network name, same extended PAN ID, same channel (25):
  • Thread 1.4.0 partition: Apple TVs, HomePods — and Aqara’s own M3.
  • Thread 1.3.0 partition, every device shown “disabled-detached”: all four of my G5 Pros, the G350, and seven Nanoleaf panels.
The M3 proves Aqara can ship Thread 1.4. The camera line apparently has not.
This is not cosmetic. My Aqara U400 kitchen lock is a sleepy device that attaches to its nearest border router — the deck G5 Pro, which sits on the detached partition. The lock attaches to a dead end and disappears from Apple Home and Home Assistant. Pulling its battery buys a temporary window until it clings to the G5 again. A door lock has to work 100% of the time. I have had to build duplicate automations in two ecosystems just to work around which side of the split the lock wakes up on.
I’m not the only owner reporting this. Other Aqara camera-hub owners are describing the same fragmentation on this forum right now, and the question “is Thread 1.4 planned?” has gone unanswered.
So three questions for Aqara, asked plainly:
  1. Is a Thread 1.4 update planned for the G5 Pro and the other camera hubs still on 1.3? Yes or no.
  2. If yes — when?
  3. If no — will you add an option to disable the Thread border-router radio on the camera hubs? Owners requested this long ago and were told it would be discussed internally. A camera that cannot join the network properly should at least be allowed to stop shouting over it.
If the answer is that these cameras stay on 1.3 forever, say that too. Owners can plan around a “no.” What we can’t plan around is silence.
I think a public clarification from Aqara would be helpful here, particularly regarding Thread 1.4 compatibility, a potential firmware update, and an expected release timeline. Hopefully, they address these concerns rather than leaving users guessing.
Welcome to the forum @AlloCodePromo.fr
More and more devices are receiving version 1.4 (Specification Version 1.4), such as the U400, Fp300, and Fp400. The new camera will feature version 1.5 ( G510, G520 ) and G5 receiving it.
Here is the U400: Aqara Smart Lock U400 - CSA-IOT
An update will therefore be released in the near future.
This is the important question. If I get no answer I will be deleting 10 G5 Pro’s from my system in the next 12 months. Thread has limits and I think one of the limits are 32 active Hubs before it pushes away the others to lay in waiting or split the Network up.
Aqara G5 Wifi certification : Aqara Camera Hub - CSA-IOT
it’s about matter version, nothing about thread version
I know; they are upgrading some devices, but there isn’t as much information available on the Thread websites as there is on the Matter websites. The Aqara MG24 module is built on the EFR32MG24 chip for Thread connectivity. This chip supports Thread 1.4, which makes a firmware upgrade technically possible. Aqara doesn’t share much with us, but hopefully, they are testing it out.
Oh wow… you went all the way to check what chip is in there and what it supports. Nice
Actually, it should not be an issue that the G5 Pro is on Thread 1.3 while the Apple Home Hubs are on Thread 1.4. My setup is exactly the same and everything runs flawlessly. They form a shared Thread network and there is no fragmentation at all. Different Thread versions alone do not cause network fragmentation.
Please also double check whether the Partition IDs are actually identical, even if they look different at first glance. Aqara and Apple display the same ID using a different byte order. So if the IDs match, your network is not fragmented. In that case, the real issue is likely somewhere else.
If your network really is fragmented, one possible explanation is that your Border Routers are too far apart and their Thread radio networks do not overlap. In this situation, communication falls back to the Thread backbone, meaning it runs through your home network over LAN or WiFi. Thread 1.3 already introduced TREL (Thread Radio Encapsulation Link), which allows compatible Border Routers to exchange Thread traffic over an IP network. For this to work and for the Border Routers to still form a single partition and accept the same Leader, they absolutely rely on flawless multicast routing.
Thread 1.4 introduces additional Thread over Infrastructure capabilities to further improve connectivity and reduce the likelihood of network partitioning. As a potential improvement, you could consider updating to Thread 1.4 once Aqara makes it available for the G5 Pro. It may improve interoperability and provide additional ways for Border Routers to maintain connectivity over your home network. However, I would not assume that this alone will fix the underlying issue.
Alternatively, I would investigate whether the Border Routers can communicate properly over their shared IP infrastructure, including the necessary IPv6 and multicast functionality.
As a workaround for an actual radio coverage problem, you could also place a Matter over Thread smart plug or smart bulb with Thread Router functionality between the two Border Routers. This would extend the wireless mesh and provide an additional direct communication path without relying on the home network infrastructure.
Regarding the question of whether you can disable the Thread wireless network on the G5 Pro as a border router: During the G5 Pro setup, if I remember correctly, the final step asks whether you want to create a Thread network or join an existing one. Has anyone tried to see what happens if you cancel the setup at this point?
It’s the backward compatibility. Thread 1.3 works on a Thread 1.4 network.
I thought about doing this but it’s not a natural choice. The natural choice means it cancels the installation of the G5 Pro.
At the time I did not realize Thread had a number of Hub limits (32) so I did not give it a second thought. A “switch” to simply toggle it OFF would solve the problem.
I’m not in favor of fixing something that’s not broken. I’m leaving things alone for now.
You are absolutely right about that.
I just did some research on this, partly because I remembered that the Thread standard is actually quite well designed. It turns out that this is handled completely automatically. If a 33rd router joins the network, nothing breaks. Instead, the system automatically determines which routers are actively needed and which are not. The extra device is simply downgraded by the network and no longer acts as an active router. Because of this automatic management, I think a manual OFF switch would not make sense here and might even violate the Thread standard.
Yes, that could be the case. I don’t know the answer and I’m glad it downgrades the device or places it in waiting.
When I originally found out some of this I began thinking about the option to just turn it off.
Turning it off is really not needed at this point.
If I understand it correctly, the Thread standard (the protocol) deliberately does not allow for manual user intervention. The idea behind this is to create a completely self organizing and self healing mesh network. Any manual interference would jeopardize this fail safe system, because rigidly assigning or removing routers could paralyze the network in the event of a location change or hardware failure.
That is how I understand it also.
Question: What happens when it fails? There is nothing we can do beyond powering ON/OFF the lead Thread device. (if you know which one it is) + that device changes as needed over time. (It’s a circle jerk) :man_facepalming:
If a leader fails or is disconnected from power, the network notices this within seconds and automatically promotes another active router to become the new leader. The network heals itself. Restarting the leader is therefore the completely wrong approach.
I do not know the exact details of this process. I would have to look into it more closely, but I am familiar with similar concepts like the Raft consensus for leader election in Docker Swarm.
By the way, in Home Assistant you can see exactly which hub is the leader inside the Matter Server app.
I use Home Assistant to help me keep track of Apple Home’s Thread Network outages. Apple Home does not offer any way to troubleshoot Thread Network issues. When Apple Home Thread devices go down there is nothing you can do other than begin unplugging and plugging back in specific devices. Leave all the “No Response” devices alone they are not the issue.
Apple Home Thread Network Leaders (Crown & Star) devices get stuck and don’t switch over smoothly. When this happens the Apple Home Thread Network goes down (so to speak) and the individual devices switch to “No Response”. Locate that Apple Home TBR and reboot it or unplug it for a moment and suddenly the Network repairs itself and switches to a different Lead (Crown & Star).
Meanwhile Aqara and Home Assistant are not effected. All their Thread devices never drop off the Network and are not effected by any of it.
The Apple Home Thread observations is kind of off topic a bit but still all related.
I do not think what you are describing is related to Thread, but rather to Matter. If it were a Thread issue, then Aqara and Home Assistant would be affected as well. Since only Apple is affected, I would say it is an issue with the Matter controller, and your Thread Leader is probably also acting as the Matter controller for Apple. When you notice these Matter issues and pull the plug on the hub, the network simply detects that the Leader is gone and appoints a new Leader. And presumably, the Matter controller either switches to a different Apple Home hub or simply restarts, and then it works again.
This also sounds very similar to what is described here:
I don’t have any way of testing that theory? All my Thread devices are Matter, so there’s nothing that isn’t Matter to compare against.
If that were the cause, you’d expect individual devices to drop out now and then, not all 23 at once (for me) in Apple Home only while Home Assistant keeps working. So I doubt it’s the main cause.
If restarting only the “Star” holder brings Apple Home back, the problem is an Apple Border router getting stuck.
(Clear as Mud)
My recent experience with my home is that the (single) thread network has evolved to be much “greener” according to Thread Doctor graphs. The self-adjusting network is working for me.
