I bought the USB versions and they work well but voltage drop on anything longer than 5m was an issue for me.
Anyone had any luck with lengths longer than 5m?
PoE version of the G5 would be a better fit for your use case, but if you don’t want to replace the G5, then you need an extension cable called “USB Active Repeater cable”.
Alternatively, you may run an Ethernet cable and build a PoE setup. Then you may USB PoE adapter/splitter to power your G5 via USB (and it will be future-proof setup, because it will allow you to use PoE in the future)
