Garage Door Auto-Close Automation
Hey everyone, I wanted to share a really handy automation I set up for my garage door. It’s been a lifesaver for me, especially when I’m juggling multiple tasks and sometimes forget to close the garage door. Here’s how I did it:
The Problem:
I have a smart garage door that I can control via my home automation system. However, I often find myself forgetting to close it, which can be a security risk or lead to pests getting in. I wanted a way to automatically close the door after a certain period if it’s left open.
The Solution:
I decided to create a simple automation using Node-RED. Here’s how it works:
  1. Trigger: The automation is triggered when the garage door opens. I’m using a contact sensor to detect when the door is open.
  2. Timer: Once the door is open, a timer starts counting down. I set it to 10 minutes, but you can adjust this to suit your needs.
  3. Check Status: After the timer runs out, the automation checks if the door is still open.
  4. Close Door: If the door is still open, it sends a command to close it.
  5. Notifications: I also added a notification to my phone to let me know that the door has been automatically closed.
Why I Chose Node-RED:
I love Node-RED because it’s incredibly flexible and user-friendly. It allowed me to create this automation without needing to write a single line of code. Plus, it integrates seamlessly with my existing smart home setup.
Tips and Tricks:
  • Adjust the Timer: Depending on your habits, you might want to set the timer longer or shorter. I found 10 minutes to be a good balance between convenience and security.
  • Combine with Other Automations: You could even combine this with other automations, like turning on lights or activating cameras when the door is open.
  • Test Thoroughly: Before relying on this automation, test it a few times to make sure it works as expected. You don’t want it to close while you’re still in the garage!
The Flow:
Here’s a quick overview of the Node-RED flow:
  • Garage Door Open Sensor: Triggers the automation when the door is opened.
  • Timer Node: Starts a 10-minute countdown.
  • Check Door Status Node: After the timer completes, checks if the door is still open.
  • Close Door Node: If the door is open, sends the close command.
  • Notification Node: Sends a notification to my phone.
Why This Works for Me:
This automation has been a game-changer for me. It gives me peace of mind knowing that my garage door won’t stay open indefinitely, and it’s been reliable since I set it up. Plus, it’s a great example of how smart home technology can make our lives easier.
I’d love to hear if anyone else has implemented something similar or has tips for improving this setup. Happy automating! :rocket:
