Garage Door Automation: My Journey and Tips
Hey everyone,
I wanted to share my recent project of automating my garage door. It’s been a bit of a learning curve, but I’m thrilled with the results! My garage door is a large roller shutter operated by a tubular motor and a ROL-605-A controller. I’ve been using an ESP8266 node (Wemos D1 mini) to detect the door’s position and control it via reed switches. It works well for detecting when the door is fully open or closed, but I ran into an issue when someone uses the RF remote to stop the door mid-way.
I tried adding an AC sensor to detect the motor’s direction, but it interfered with the controller’s internal circuitry. After some research and trial and error, I found that using a quad-relay controller to manage the motor’s up and down signals worked perfectly. I set up each relay to control different aspects of the door’s movement, and now I have full automation without any hiccups!
For anyone looking to tackle a similar project, here are a few tips:
  1. Start Small: Begin with basic automation and gradually add more complex features as you gain confidence.
  2. Understand Your Equipment: Spend time reading manuals and understanding how your devices work. It saved me a lot of frustration!
  3. Test Thoroughly: Before fully committing to a setup, test each component individually to ensure everything works as expected.
  4. Join Communities: Forums like this are invaluable. Don’t hesitate to ask for help or share your experiences.
If anyone has questions or suggestions about garage door automation, feel free to reach out! I’d love to hear about your projects too.
Happy automating! :rocket:
