Hello everyone, I’m trying to set up an automation to close my garage door if it’s left open for more than 5 minutes. I’ve read through several examples, but I’m still having trouble getting it to work properly. Here’s what I’ve done so far:
I have a cover entity for my garage door (cover.garage_door) and I’m using an automation that triggers when the door is opened. The trigger includes a delay of 5 minutes to give me time to close it manually if needed. If the door is still open after that time, I want it to close automatically.
Here’s the code I’m using:
yaml
alias: Door open
trigger:
- platform: device
device_id: 3ac70e1d66eec172cab97d178449cf36
domain: cover
entity_id: cover.garage_door
type: opened
for:
hours: 0
minutes: 5
seconds: 0
action: - service: notify.notify
data:
message: The garage door is open!
actions:
- service: cover.close_cover
title: Close
data: {}
target:
The notification works perfectly, and I see the ‘Close’ button in the notification. However, when I tap the button, nothing happens. The garage door doesn’t close. I’m not sure if there’s an issue with the way I’ve structured the automation or if there’s a missing piece in the configuration.
I would really appreciate any guidance or suggestions on how to fix this. Maybe there’s a different way to structure the automation or a service I’m not aware of that can help with this. Thanks in advance for your help!
