Garage Door Monitoring and Automation Setup Guide
I recently set up a garage door monitoring system using my VeraLite controller, and I wanted to share my experience in case it helps anyone else. My goal was to receive notifications if my garage door remained open after a certain time, which I achieved by combining a garage door controller (LFM-20) with a door/window sensor. Both devices were straightforward to install and integrate into my Vera system.
For those looking to add a similar feature, here’s a quick guide:
  1. Hardware Setup: Install the garage door controller and sensor. Ensure they are within range of your Vera hub.
  2. Vera Configuration: Add both devices to your Vera system through the device setup wizard.
  3. Automation Rule Creation: Navigate to the automation section and create a new rule. Set the condition to check if the garage door is open after 8 PM. Trigger a notification to your phone.
This setup has been a great addition to my home security. It gives me peace of mind knowing that I’ll be alerted if my garage door is left open, even when I’m not home. If anyone has questions or needs help setting this up, feel free to ask!
Happy automating! :fire_engine:
