Garden Irrigation System Without Internet
Hello everyone, I’m excited to share my recent project of setting up an automatic garden irrigation system without relying on the internet. I’ve always been passionate about gardening, and automating this process has been a long-term goal of mine. Here’s how I approached it and what I’ve learned along the way.
The Setup
I decided to use a CCU2 as the central controller for my system. It’s been a reliable choice for home automation, and I wanted to take full control programmatically. The system includes a pump and two magnet valves—one for watering the lawn and another for the flower beds. The CCU2 allows me to schedule the irrigation times, set the duration, and even switch between manual and automatic modes directly from my phone using the Tinymatic app.
Challenges and Solutions
One of the initial challenges was ensuring that the system could run without an internet connection. I chose LTE connectivity for the CCU2, which provided a stable and reliable connection without the need for a traditional broadband setup. This was crucial for my rural location where internet infrastructure is limited.
I also faced some issues with valve synchronization. Initially, the valves didn’t open or close as expected, but after some troubleshooting, I realized it was a matter of adjusting the timing in the app. The Tinymatic app proved to be very user-friendly, allowing me to tweak settings on the go.
Tips for Others
If you’re considering a similar project, here are a few tips:
  • Start Small: Begin with one valve and test the system thoroughly before adding more components.
  • Check Compatibility: Ensure all your devices are compatible with your central controller and the software you plan to use.
  • Regular Maintenance: Schedule regular checks for the pump and valves to prevent any unexpected downtime.
Conclusion
Setting up this irrigation system has been a rewarding experience. It’s not only saved me time but also ensured that my garden gets the consistent care it needs. I’m now looking into expanding the system to include soil moisture sensors, which would make the irrigation even more efficient.
If anyone has questions or suggestions, I’d be happy to discuss further. Happy gardening! :seedling:
