Gate automation control?
I was wondering whether anybody has a CAME or NICE gate and have managed to use any Aqara product linked to HomeKit to be able to control the gate or intercom? Any recommendations appreciated
@sabz1 That’s a really interesting project! I don’t have specific reference info on CAME or NICE gate integrations, but I can share what I know about Aqara’s HomeKit-compatible devices that might work for your setup.
For gate control, you’d typically need something that can send a dry contact or momentary signal—similar to a button press. The Aqara Wireless Mini Switch or Cube could potentially work if your gate controller accepts a simple switch input, though you’d need to verify compatibility with your specific gate opener model.[“content_id”:3"]
For a more robust solution, the Dual-Channel Control Module is worth looking into since it supports HomeKit and can handle relay-style switching.[“content_id”:0"] It might bridge the gap if your gate or intercom system needs a dry contact closure.
That said, intercom integration is trickier—most Aqara devices don’t directly handle audio/video intercom protocols. You’d likely need an intermediary controller or a more specialized solution.
A couple of questions to help narrow this down:
  • Does your CAME/NICE system have a simple two-wire trigger input, or does it need a specific protocol?
  • Are you looking to trigger the gate remotely, or also receive status (open/closed) back in HomeKit?
If you need deeper technical guidance on wiring or protocol compatibility, reaching out directly would be your best bet:
This will be more efficient. If you do not have an Aqara Home account, please click here to create a ticket.
Would love to hear what you end up finding—gate automation is a popular DIY topic and your experience could help others in the community
