GE/Jasco In-Wall Outlet Pairing Trick - Success Story!
I wanted to share a success story that might help others struggling with pairing GE/Jasco in-wall outlets to their SmartThings hub. After hours of frustration and trying every documented method, I stumbled upon a simple workaround that finally worked!
The Problem:
I had two GE/Jasco 12721 outlets that simply wouldn’t pair up, no matter what I tried. I followed all the standard pairing sequences, did device exclusions, tried power cycling, and even searched for alternative solutions online. Nothing worked—until I tried this method.
The Solution:
Here’s what did the trick for me:
  1. Plug a lamp into the lower (Z-Wave controlled) receptacle.
  2. Cycle the power using the push button.
  3. Unplug the lamp and move it to the upper (non-controlled) receptacle. The light should turn on.
  4. Unplug the lamp again and place it back in the lower receptacle.
  5. The push button should now toggle the light switch.
  6. Go to your SmartThings app and add the outlet as a Jasco in-wall outlet.
Why It Worked:
I believe this process helps the hub recognize the outlet by creating a temporary connection that ‘trains’ the hub to see the device properly. It’s a bit of a hack, but it worked perfectly for me!
Outcome:
Both outlets are now paired and working seamlessly in my SmartThings setup. No more frustration, and I can finally control them through my app!
Tip for Others:
If you’re having trouble pairing, try this method before giving up. Sometimes a simple trick like this can save you hours of troubleshooting!
Happy smart home hacking! :blush:
