I recently installed the GE/JASCO Z-Wave 45613 Three-Way Dimmer Set, and I wanted to share my experience and some tips that might help others who are facing similar challenges.
Initial Setup and Frustration
At first glance, the installation seemed straightforward, but I quickly realized that the instructions didn’t quite match my existing wiring setup. This led to a lot of confusion and frustration, as I tried to figure out how to make the switch work without rewiring my entire home. I spent hours researching online, reading forums, and watching tutorials, but nothing seemed to quite solve my problem.
Key Insights
After several failed attempts, I finally had an epiphany. The GE/JASCO Z-Wave 3-Way Set is designed to work differently from traditional 3-way switches. The master switch (ZW3003) and the auxiliary switch (ZW2002) communicate wirelessly, meaning the auxiliary switch doesn’t need to be directly connected to the load. Instead, it sends a signal to the master switch, which then controls the circuit. This was a game-changer for me, as it simplified the installation process significantly.
Wiring Tips
- Master Switch (ZW3003): This switch requires a standard 3-way wiring setup with line, load, neutral, traveler, and ground wires.
- Auxiliary Switch (ZW2002): The auxiliary switch doesn’t need a line or load connection. Instead, it uses the traveler wire to communicate with the master switch. The neutral wire is still required for proper operation.
Common Pitfalls
One thing I learned the hard way is that the auxiliary switch must have access to a neutral wire. If your installation doesn’t have a neutral wire available, you’ll need to run one from the master switch or use a different type of switch. Additionally, the switches are always on when installed, so make sure to test them thoroughly before finalizing the installation.
While the installation process was a bit challenging at first, the end result is well worth the effort. The GE/JASCO Z-Wave 3-Way Dimmer Set is a reliable and innovative solution for controlling lights wirelessly. If you’re considering installing one of these sets, I highly recommend taking the time to understand how they work before diving into the installation.
If anyone has additional tips or experiences to share, I’d love to hear them! Happy installing! ![]()
