After dealing with several dead GE Jasco Z-Wave smart switches, I decided to dive into the repair process. It turns out to be surprisingly straightforward! Here’s a quick guide to help others who might be facing the same issue.
**Repair Process:**1. Disassembly: Carefully take apart the switch. The main issue seems to be with the internal capacitor.
2. Component Replacement: Replace the faulty capacitor. This part is easily sourced and inexpensive.
3. Reassembly: Put everything back together. The whole process takes about 10-15 minutes per switch!
**Cost Efficiency:**Each repair costs roughly 5 cents per switch, making it a cost-effective solution. I’ve now repaired several switches, saving myself from buying new ones.
**Why It Matters:**These switches are great for controlling lights and appliances, but their reliability can be hit or miss. Knowing how to repair them adds a layer of sustainability and cost-saving to my smart home setup.
**Pro Tip:**Keep a stock of replacement capacitors on hand. It’s a small investment that pays off in the long run!
If you’re considering this repair, check out my detailed teardown and repair guide on YouTube. Happy fixing! ![]()
