As my family was preparing for an extended trip away from home I wanted the lights controlled by Aqara switches and outlets to go on and off at seemingly random times. I used ChatGPT to create the schedule. I told it which room had the lights, what our typical schedule was like, and that I wanted the house to appear lived in. It came up with a schedule that I programmed with the Aqara app.
@jkusters That’s a really solid (and surprisingly practical) use of ChatGPT—especially for “lived-in” lighting where a perfectly repetitive timer schedule can look a bit too robotic.
If you’re open to refining it further in Aqara Home, a couple ideas that tend to work well:
- Layer schedules + scenes: Instead of one big schedule, break it into a few “anchor” moments (early evening, late evening, bedtime) and trigger Scenes from those. Easier to tweak later without rewriting everything.
- Add small offsets: Even if your base schedule is fixed, adding small variations (like 10–25 minutes) across different rooms helps sell the realism.
- Mix room logic: Living room + kitchen earlier, then move to hallway/bedroom later—matching how people actually move through a home.
- Don’t forget voice/app control options: Aqara switches support app remote control and timers/schedules, so you can always override things remotely if plans change.
If you share (1) which rooms you included and (2) the time window you want “activity” (e.g., 6pm–11:30pm), I can suggest a simple structure for splitting it into scenes/automations that’s easy to maintain.
This is a really clever use of ChatGPT ![]()
One thing I’d love to see Aqara add natively is a vacation / presence simulation mode that adds a bit of randomness automatically.
For example, instead of turning the living room light on at exactly 19:30 every night, it could vary within a window, occasionally skip a room, or turn different lights on in a realistic sequence.
Something like:
- Living room: sometime between 18:45–20:00
- Kitchen: short periods around dinner time
- Bedroom: later in the evening
- Small random variations each day
That would make the house look much more naturally occupied without having to build a large schedule manually.
Your ChatGPT workaround is actually a great way to achieve that today though — definitely stealing this idea for my next trip ![]()
